one server, one vendor, different licenses
Hi everyone,
we want to license the product Mathcad 14 and Mathcad 15 with the daemon pst_d.exe with two different licenses (Mathcad 14, Mathcad 15)
The flexera support said we need one license server for each license because the licenses use the same vendor daemon (ptc_d.exe)
But we want only one Server for every license. I hope I explain the topic clearly enough.
I tried to rename the daemon or tried different port-options, nothing helps.
It would be great to fix this problem and I'm very grateful for every tip.
Thank you very much!
with best regards,
Christoph
Do you use "Floating" type of licensing for both Mathcad's (14 & 15)?
yes we use the "Floating" type of licensing for both.
Try to copy into the license file for Mathcad 15 only license feature ("Mathcad Add-On Collection" (4 pieces) and "Mathcad REP" (1 piece)) from the license file for Mathcad 14. Then reread license file and restart license manager Flexnet.
