Optimisation of a variable
I have a Mathcad document along the lines of:
r:=10mm
Many equations using r and other variables.
stress = 50 MPa
Is there a way to find the value of r that gives the minimum stress without totally re-writing the document?
I know this can be done relatively easily for discrete values of r by using a vector but I'd ideally like to do the equivalent of an Excel goal seek.
Turn your calculations into functions dependent on r, so that at the end you have a function stress(r):=.....
Then use "minimize".
23-Emerald I
If you have stress as a function of r, then Minimize will do what you want.
Hi Dan
try this one. Some simple equations that spit out a minimized value.
Hope it helps
Raiko
Dan8881-VisitorAuthor
Trouble is my worksheet is long and complex and is not written using functions but straight definitions e.g. B:=2r rather than B(r):=2r
It doesn't look like it is possible to do what I want without rewriting every equation as a function of r because Minimize only works with functions.
Might be easier to set up the same equations in Excel and use solver as there are a few input variables apart from r that I'd like to change.
Is there a way to do it along these lines:
Given
r:=10
stress:=r^2
5<r<20
stress<1
Minerr(stress,r)=(1 over 10)
The stress<1 line is an attempt to force it to find the minimum value of stress even though it has to be higher than 1 to satisfy the constraints.
Why does the above not give (5 over 25)?
Here's another attempt:
Given
r:=10
stress:=1000
stress=r^2 (boolean equals this time)
5<r<20
stress<1
Minerr(stress,r)=(1.962 over 1.71)
If I right click Minerr and change to one of the other non-linear methods it gives (8.16 over 3.5) which is a bit closer to the correct answer of (25 over 5)
Why does it give these answers?
23-Emerald I
If you have a range for r (that it must stay inside), replace the single value r:=10 with a vector of values that covers the range. It may be necessary to "vectorize" a few of you equations, but the sheet should compute and result in a vector of stresses--one for each value of the radius vector. Plot stress vector against r vector, or develop a curve fit between the vectors, to find the minimum.
