8-Gravel
Out of memory error
I am using Mathcad 15.0 M050
I started getting an Out of memory error popup window, coming at random times when my MatchCAD file is open but not even running.
I added memory to my computer to increase its memory several times.
This did not reduce the occurrance of the Out of memory error at all.
Here are the errors that I faced
Out of memory
    VipulTAnswer
    Hi @bbobbs,
    Try to use a different user profile for login and see if the issue persists. With this it can be narrowed down whether the issue is system specific or user profile specific.
    Vipul
    Hi @bbobbs,
    Please share the dxdiag report of the system having issues with.
    To get the DxDiag report: Click Windows Start button > type “DxDiag” in the Search box, and then press ENTER > Save all information to “DxDiag.txt
    Also, are you saving the file locally or on a shared network location?
    Vipul
    VipulT16-PearlAnswer
    Hi @bbobbs,
    Vipul
    bbobbs8-GravelAuthor
    8-Gravel
    Thanks!
