Pasted a Material Table from Excel, Lookup values
- 8 replies
- 2652 views
- Translate All
i don't want to read excel file to get the material properties for a given section. As you can see in the attached file, i copied the material section properties and pasted it into mathcad prime. Is there a way the user can select the material as i am showing below the table TC= " A22B", and have it look up certain section properties. I was able to do it in MathCAD 15.
Sam
