Apr 20, 2025 4:20 PM UTC
Pasting MathCAD code from Chatgpt need to be manullay typed again
The MathCAD code generated by Chatgpt is pasting as text instead of Math input, and due to this issue it need to be manually typed in MathCAD.
Is there any solution exist for this issue.
LucMeekesAnswer
23-Emerald V
Apr 20, 2025 5:19 PM UTC
No, there isn't.
Personally I doubt that any code by ChatGPT (or any other AI interface) will produce valid MathCad input.
Care to show what you've gotten from ChatGPT?
LucMeekes23-Emerald VAnswer
23-Emerald V
No, there isn't.
DJNewman
Apr 21, 2025 3:53 PM UTC
This isn't the first time I've seen someone claim that ChatGPT can produce Mathcad input (that isn't something for an Advanced Controls script), but I have no idea how such a thing can even be possible.
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
23-Emerald V
Apr 21, 2025 5:16 PM UTC
Well, ChatGPT is being used  for programming. It apparently is quite helpful to create Python, C and basic code. I would not be surprised if it also does lisp. And Prime equations appear to be stored in a lisp-like language.  If ChatGPT would come up with this:
(@EQ (@DERIV t @PLACEHOLDER (@APPLY (@ID V (@SUB x)) (@ARGS t))) (+ (* D (^ (@ID V (@SUB x)) 2)) (* (* M (@APPLY (@ID V (@SUB y)) (@ARGS t))) (@ID S (@SUB y)))))
when pasted into an empty math placeholder it is shown by Prime as
But then... one equation doesn't make a sheet.
