PDF file formation from Prime 10 using Win 10
Are there any file format rules about "Save as PDF or "Print to PDF?
I generate 30 page workshheets with a few plots with many line styles and trace colors.
Very often the PDF conversion process ignores some colors and changes line styles.
Text and graphics are well spaced.
This has become an on and off case-file for some time and I am working with a PTC help agent in India.
On one occasion I removed all text and plots were perfect!
We have no ideas about the problem.
Files will not be shared online:  Patent submission.
Apart from Primes export facility and the Microsoft Print to PDF driver you may try some other PDF printer drivers like CutePDF, Adobe PDF Print, FreePDF, doPDF, PDF24, 7-PDF, etc. A lot of them a free, others usually offer a trial period during which you can test the software.
JeffH1
PDF995 is free as well.
BlueBeam is not free ($260), but we use it at my place of employment and it's a full-featured replacement for Acrobat Pro.  It also has a free trial.
Thanks for your reply. I had totally forgotten about this procedure.
I tend to get very focussed on design problems; I am 88 and probably too old to change!
When we install Mathcad Prime 10 we also get some Adobe files, and I was
surprised to discover the PDF "Save as" or "Print to" processes were not standardized for colors or colours.
I was sure that I was doing something wrong with Mathcad Prime and spent way too much
time hunting for my errors. My first Mathcad was on a 5.25 inch floppy disk!
Finally settled on CutePDF as is did not mess with plotted line styles.
