Pipe Thrust Forces
- 24 replies
- 9186 views
- Translate All
I know Lusk recently posted some files on this, but it was not really what I was looking for. I am trying to be able to generate a table of thrust forces at select junctions in my pipeline. Currently, it is set up for one pressure, but I want to evaluate multiple scenarios in this sheet. Pressure for steady state, test, surge (e.g. 20, 50, 35). The middle one only has a static component, but the others require analysis. The other problem I need to figure out, may be a programing issue, is the restraint for a dead end. The X component using 90 degrees is correct; however, you plug in 0 for your angle and the result is 0. Functions, programming, etc. are all fair game. I'd like a CSV dump to send to a spreadsheet when all is said and done. Your help is greatly appreciated in
