Pivot table values from excel inserted to a matrix
please see attachment . i am manually copying and pasting each value from the pivot table into the matrix. is there an easier way to automate this process? the size of the table can be any square table meaning number of rows= number of columns.Thanks!
23-Emerald V
You need to generate your header, then stack it on top of the array,
then transpose the header, stack a space on top of it, then augment it to the back of the previous array.
Stuart
23-Emerald V
Stuart
SFares14-AlexandriteAuthor
Thank you so much Stuart!
23-Emerald V
No worries. 🙂
