Pivotisation of a matrix - I try to change an existing file that works with another scheme
I have a Mathcad file that do the pivotisation of a matrix but I dont like it because is too indirect and obscure.
I want to implement another scheme that is more explicit and easily understanding but does not works by now. I attached my working file that also contains the scheme that i try to implement.
23-Emerald V
In your Piv(Aug)  function, you let i run through all rows (from 1 to n), then you start k at i+1. That is bound to fail when i=n, because then k=n+1, which is out of range.
Potential remedy:  in the first FOR statement, change:
"for i e 1..n"  =>  "for i e 1..n-1"
tubar1-VisitorAuthor
I found the solution. Thks!
I attached the file.
terryhendicott
Is this  where you are ultimately heading.
Cheers
Terry
