23-Emerald V
Like this?
If you want the other graph, you will have to provide the expression for the Gerber parabola.
kenan21-VisitorAuthor
is it possible to make it a little more presentable ? Like this maybe:
terryhendicott
Hi Kenan
To find more adjustment in a plots features you need to use the chart component new in Prime 6.
The plot component is found on the menu Math | Regions as a drop down list.
One is enclosed in file attached. Double click it to activate format options.
23-Emerald I
The plots--sure!  🙂
The labels--well, you're on your own.
