Plot function
We want to define a function that gives the values
f (a) = 2a when a is between 0 and 5
f (a) = 10 when a is between 5 and 10
f (a) = 0 all other times
and then plot the function with that range −5 < a < 15
I have tried it but my plot just don't seem right look at the attachment. can you show me how to do it in MATHCAD
Why? Your plot is showing exactly what you want with just one exception - there is nothing plotted in the range from-5 to 0, because your function is not providing values for a<0. This can be repaired if you replace the last if-statement by an otherwise-statement.
For further questions please note that its adviseable to attach your worksheet, not just a screenshot.
What you have is correct (or almost correct, anyway). What makes you think it's wrong?
The graph would look better if you changed the y axis limits a little. If you click on the plot you will see placeholders at the top and bottom of the axis. Try typing in -1 and 11 for the limits.
Also, your function is technically not quite correct. The second line says that if a=10 then the result should be 10, but the third line says if a=10 then the result should be 0. The statements should not overlap. Also, replace the last one with "otherwise", which also covers the case when a<0.
