Plots are not copying clearly to powerpoint while using dotted lines in x-y plot
In the x-y plot,
the plots are not copying to the
powerpoint clearly, when I choose dotted lines(Traces--> line-->dotted lines)
Please go through the attached file
for clear understanding of my question.
Please help.
RichardJAnswer
The error is in the metafile Mathcad creates, so it is what it is. It's been like this for years, and it's unlikely to ever get fixed. I use one of two approaches to get around it. One is to paste the graphic into a drawing program such as Adobe Illustrator, and clean it up there. So in your example I would paste with solid lines, and then change the lines to dashed in Illustrator. The other approach is to create a table of the data, copy and paste that into Excel, and create the graph there. If I need a top quality graphic then I may even create the graph in Excel, and then edit it in Illustrator.
Paste as a metafile rather than an enhanced metafile.
vveeran4-ParticipantAuthor
If I paste as a metafile, the picture quality is not good.
Only if I paste it in enhanced metafile,
the picture quality is good.
Is there any other procedure to copy and paste
without affecting the picture quality.
RichardJ19-TanzaniteAnswer
