Plots Change Size in Mathcad Prime 8
I have a Mathcad file where many of the XY plots get larger when I open the file.  If I drag the plot handle to scale them back to their normal size, they get large again the next time I open the file.  This started happening with Mathcad Prime 8, and it only happens to one file, so far.  The left upper corner of each plot remains fixed, its the bottom right corner that changes location.  There are many plots in this file, and it is getting old having to resize them all each time I open the file.  These are the embedded plots, not the Chart Components.  This file is being opened from one computer.
i can't confirm this behaviour as I do not use Prime 8  - actually I am not really using Prime at all as long as real Mathcad (v.15 and below) is working.
But i would suggest you report this as a bug in Prime 8 to PTC support.
23-Emerald V
Can you attach the file? So I can have a look.
