Plotting a trigonometric function
- 1 reply
- 1375 views
- Translate All
Hello everyone,
I am trying to create a plot to find the critical phase angle affecting a pipe.
When I created the calculation in Mathcad15 everything works fine. See the file attached.
When I reproduced the calculation in MathcadPrime3.0, I am getting errors such as "the variable is undefined", "plotting failed", etc. See the file attached
Can someone please let me know how to fix the MathcadPrime3.0 calculation?
I am having trouble calculating the lift of drag force for several values and then using these to create a plot. If input F(4) or F(6) everything is fine. But if I say F(x), and x is a matrix with several values, then the equation crashes.
I would really appreciate your help.
Thanks!
-Ritchie
