Plotting boxes in 3D
Hi everyone!
I am trying to find a better solution (working for many more "boxes") for the problem exemplified in the attachment. I have a list of "boxes", defined in a matrix of X,Y,Z coordinates.  I would like to get a 3D representation of the boxes. What I have attached works, of course, but it would be much better if one could represent the "walls" of the boxes, without all the points inside.  Is this too much for MathCAD?  what do you think?
Thanks a lot for any hints!
Regards
Claudio
Werner_EAnswer
Here is my second attempt. This time all boxes represent just one single plot, but the boxes are now connected by a line which is of course disturbing. Only way to get rid of this is to do without potting the wireframe lines.
But at least you won't run into some kind of limitations and don't have to go through the hassle of having to format the style of every box at its own. See here a sample plot with 100 random boxes:
I guess you would have to dig into
https://community.ptc.com/t5/PTC-Mathcad-Questions/Creating-Amazing-Images-with-Mathcad-14/td-p/441375
Still the bible when it comes to plotting in Mathcad
Hey Werner, thanks!  I wasn't aware of this. The E-book is really the exe-file attached to the post? it is somehow an unusual format ...
Regards
Claudio
You might also be interested in the article of uni (Viacheslav N. Mezentsev ) - see the last post in this thread:
https://community.ptc.com/t5/PTC-Mathcad-Questions/Ploting-finite-triangle-and-rectangle-in-3D-plot/td-p/327681
Its in russian but the pictures of the first few pages should give you a hint how to create a box.
Here is my first attempt using some data structure from the "amazing images".
Unfortunately it creates a separate plot for each box which may make you run into some limitation if you'd like to plot a lot of boxes (apart from having to set the appearance for each box in an extra step.
In the E-book there are routines which can make it just one single plot (if you have the time to dig into and experiment).
Werner_E25-Diamond IAnswer
I wish to thank you very much, Werner, both for making me aware of the "Amazing Images" E-Book (it works! 🙂 and for even programming the requested solution for me!  I certainly had required more time! I was still wondering at the book ...
Regards and thanks a lot again
Claudio
