Plotting cosine failed, "replace complex values and NaNs by real numbers"
In attached file I'm trying to plot a function of time but am getting a "Replace complex values and NaNs by real numbers".  If I include units in my "t" range definition I can plot my second function.  If I exclude units I can plot my first function.  But not both at same time.  I can't see what is wrong.
ttokoro
ttokoroAnswer
t with unit.  Then bottom plot can make.
t.t.
Your range for t is defined unitless!
Thats OK with the unitless function v.AB, but in d(t) you use "d0" and "velocity" with correctly assigned units. So you have also to use a range for t with units as otherwise you run into a unit mismatch as you can't add feet and feet/seconds.
Define t:=0s,10^-6 s .. 0.01 s (you have to add a time unit to all three values).
Hi Werner,
Yes, and as you will see in my attached file, when I do define the units (exactly as you describe), then the bottom plot fails.  How do I correct that?
thank you
ttokoro
ttokoro21-Topaz IAnswer
t.t.
18-Opal
terryhendicott
Distance is the integration of velocity.  The velocity varies so you need to do this.
Cheers
Terry
Hi Terry - in this case my Vab is a voltage, not a distance.  But, thank you.
