Plotting Issue
- 2 replies
- 1470 views
- Translate All
I have what is probably a simple plotting issue. It occurs at the bottom of the attached worksheet. I am comparing four outputs from Odesolve and Radau: velocity, stress, porosity and pore pressure. When I plot the velocity and stress together there is no problem (I know there are some differences in the peaks, but I understand why this is happening and it is not the issue). For the porosity and pore pressure, the outputs look ok if I put them on separate plots, but if I put them on the same plot, the output from the second quantity on the plot (from Odesolve) does not seem to plot correctly.
