Plotting using text
  • April 25, 2010
  • 3 replies
  • 4267 views
I would like to plot using text (Jan, Feb, Mar, etc) my calculations using integers, but it is hard to see the results. Any suggestion
Could you post an example of what's required, or at least close to what you want.
Maybe show what you have previously been producing.
In general, that's something I would port to Excel and plot therein
TTFN
Good idea the data could be passed to Excel and the graph produced there. Inserting Excel components is messy and usually takes a lot of playing around though.
You can place text boxes over the required sections of the graph.
Cheers
Mike
You label the exes of Mathcad graphs with text, so, as already suggested, an Excel component is about the only option. Your only other option is to download the e-book here:
http://communities.ptc.com/community/mathcad/mathcad_usage/blog/2010/05/27/creating-amazing-images-with-mathcad-14
That shows you how to put text on graphs, but you still have a lot of work to do to make a labelled axis!
I have just downloaded and installed the suggested e-book which has some fantastic features - A little above my Mathcad knowledge I must add. I doubt the original poster will find what he is after in there.
If he is after labelled axis - Excel is the way to go.
I only said it was a possible solution. I never said it was an easy one
