May 17, 2024 12:24 AM UTC
+/- Plus/Minus sign Mathcad Prime?
Does Mathcad Prime include a ± plus/minus sign or symbol?
ttokoro
May 17, 2024 12:53 AM UTC
I think the answer is no. You can only use special fonts that windows can display like yours. However, it is no meaning. So you must define it to use.
t.t.
May 17, 2024 3:45 PM UTC
Thanks @ttokoro  -  I figured it was worth adding (with slight hopes that they added the ± operator in Mathcad Prime)
May 17, 2024 1:40 AM UTC
In which way would you like to make use of such a sign?
You can create a function like
and use it that way
In real Mathcad you can also use it as infix operator
but in Prime this option (like so many others) is not available.
You can create the function in Prime but you only can use it in prefix mode with argument parenthesis
You may also define it as
but I guess this only makes sense if you can use it as infix operator.
May 17, 2024 4:45 PM UTC
Thanks @Werner_E  - When I get around to installing Mathcad Prime 10 I'll have a look at your example document.   But, my typical use of the plus/minus operator is, well, an operator.   I'll have to see if I can use a function instead of a variable.
Why did we move to Mathcad Prime if they don't have the ± plus/minus operator?
23-Emerald V
May 17, 2024 5:45 PM UTC
What is your definition of the '+/- operator', what does it do according to you(r use of it)?
