Pneumatic Conveying with Mathcad Prime 2.0
A question was raised if the capacity of an existing pneumatic conveying system, conveying HDPE particles, can be increased from 20000lbm/hr to 30000lbm/hr ?.
This worksheet shows the calculations with unit conversions used in the system evaluation. Summary of calculations results are given with the references.
-MFra-
Probably you could find an expert in the page relating to the mechanical engineering ...
aallawi1-VisitorAuthor
>Sir,
>             The question raised was rather general and does not reflect an
>existing system in reality.
>I took this, as an idea to use Mathcad Prime 2.0, as an example, with
>units to show the readers. I attach the pdf format to allow others who does not have Mathcad software, to see it.
>My mechanical engineering background was supported through the works I
>have done in DCS's for various industrial and power plants, also for the new
>geothermal power plant which is going to be used for the first time in
>Iraq.
>Regards,
>a allawi
