8-Gravel
Positive and Negative result
can you help me, sir, for solving this problem, I want to solve (Icr) term?
ttokoro
ttokoroAnswer
Last equation. After you can solve dc, then put the answer to dc.
Unit of right first is m^2, second and third are m^4. So can't solve.
t.t.
Attach your worksheet to the message.
8-Gravel
-thank you sir for your response,
- the file is attached with name (slab bs-5400)
23-Emerald V
You should ALWAYS attach the Mathcad/Prime worksheet, not just a picture.
Apart from that:
- In the definition for Icr, you should explicitly type a multiplication symbol   *
        between As' and (dc-d)
       as well as between As and (d-dc).
If not As' and As are considered functions.
- If you only need numerical results, you should use the root function, or a solve block, to determine the value of dc.
Note that the symbolic processor of Mathcad/Prime does not 'know about units' by default.
But first: attach your worksheet.
8-Gravel
ttokoro
ttokoro21-Topaz IAnswer
t.t.
