-MFra-
Possible interaction between AutoCAD2000-mathcad-prime-3.1 or mathcad 15.
Goodmorning everyone.
As AUTOCAD user (the latest version that I use is the 2000) for several decades, I would like to know if it is possible an interaction between AutoCAD2000-mathcad-prime-3.1 or mathcad 15.
Thanks for your kind attention
With best regards
FM
Hi F.M.
You can download http://download.ptc.com/products/mathcad/addins/AutoCAD-Mathcad.zip from http://www.ptc.com/engineering-math-software/mathcad/free-download/free-plugins-for-mathcad-users/autocad-integration . Inside the zip file there are a word document explaining how to do the integration, but with autocad 2008. The other files in the zip are the vb script code for autocad and a mathcad file.
Best regards.
Alvaro.
For Mathcad Prime 3.1 version, in addition to built-in integration with Creo Parametric, now there are only a plugin for integration between Mathcad Prime and SolidWorks is available (this integration is built as a SolidWorks Add-In for SolidWorks 2014 and 2015): Thank You for Downloading PTC Mathcad/SolidWorks Integration Add-In | PTC
