Preliminary design hydroelectric station problem without Prime units.pdf
Hello EE Community,
I had a hydro power station preliminary design which had 'unit' mismatch, and some conversion ambiguities.
Here is a revised file with those problems solved if any you may clear them yourself. The cost per kWh is may be low to you, those are just rough numbers.
Sincerely,
Karl.
