Pressure flow system example 11.6.mcdx
EXAMPLE 11-6 CHAPTER ELEVEN, GUPTA
        developed by Carlos Day, PE, MBA, M.ASCE
Two reservoirs are connected by a 200 ft-long cast iron pipeline. If the pipeline is to convey a discharge of 2 cfs at 60 , what is the size of the pipeline required?
-MFra-
I hate to tell you, but on my own, things are done well when using the units. (the dimensionless variables will be created there where required.).
Bye
