3-Newcomer
Prim 9.0 - PDF of whole document
I have a documents that has elements on the right of the document "page" (viewable in the "draft" view).
I tried multible ways to generate a PDF ("save as"; MS print2PDF "all"; select all elements and then in print dialog "selection") where I can see all content but I only see what's viewable in the "page" view.
Increasing the page is not an option as I'm already at "A3" size.
See attachments.
Regards
Holger
Does anybody
Werner_EAnswer
I see no way to achieve with Prime what you are looking for.
In old Mathcad we  had an option to also print the content to the right of the page (was not implemented optimal) or we also could chose a paper size of A0 or even larger and let the printer driver do the scaling and/or posterization.
Unfortunately Prime does not offer either facility and so I guess all you can do is to suggest to PTC that they implement in a future version some way to also bring the content placed to the right of the page border to paper in some way.
All you can do with current version of Prime is to scale down the font size of math and text to something so small that your whole work fits within A3 landscape. Of course with an already existing worksheet this means a lot of reformatting (position of the regions, size of the plots, ...).
An option like "fit to one page width" for automatic scaling of the whole sheet like we have in text processors would be a nice feature for a future version of Prime ...
Werner_E25-Diamond IAnswer
