Prime 2 won't save my changes - Help!!
I have a large worksheet that was converted from 15.
Today I made a number of corrections to some of the assumptions that new data has clarified.
When I try to save the file, I'm getting this error:
similar to the error I receive when I'm trying to open a Prime 3 file...
the information in the log file is uninspiring.
here's an extract:
Exception data:
File being saved: ..\Desktop\48V ph1 dcdc Full bridge 2tx 25 1 2016 with litz - Copy - Copy.mcdx
System.NullReferenceException: Object reference not set to an instance of an object.
   at Ptc.Controls.EquationControl.GetDisplayMatrixCell(IMatrixResultNode matrix, MatrixFormat matrixFormat, Int32 r, Int32 c, Boolean useEagerMatrixForSmallMatrix)
   at Ptc.Controls.EquationControl.ConvertToEagerMatrix(IMatrixResultNode originalMatrix, MatrixFormat matrixFormat, Boolean useEagerMatrixForSmallMatrix)
   at Ptc.Controls.EquationControl.ConvertToDisplayMatrix(IMatrixResultNode originalMatrix, MatrixFormat matrixFormat, Boolean useEagerMatrixForSmallMatrix)
   at Ptc.Controls.EquationControl.ConvertAnyFormattedMatrixToDisplayMatrix(IResultNode resultNode, MatrixFormat matrixFormat, Boolean useEagerMatrixForSmallMatrix)
   at Ptc.Controls.EquationControl.get_EngineResultForSerialization()
   at Ptc.Calculation.Core.ResultManager.GetEngineResultForSerializationFromCalculatable(ICalculatableResultOwner resultOwner)
   at Ptc.Calculation.Core.ResultManager.AddResult(ICalculatableResultOwner calculatable)
I am going to try a line by line check between the current saved file & the modified version, but it is a mammoth task and since I don't know what I'm looking for I don't hold much hope for success.
Has anyone seen anything like this or any suggestions how to preserve the changes that I've made?
  Andy
Thanks Richard,
This helped.
I have tentatively identified a glitch in an included file that is promoting the problem, but I'm not sure what it is.
There were a few changes made & prime doesn't automatically update the results if the included file is modified (even when the file is re-opened; it seems that the last image is used rather than reloading the latest version...).
So I can't say exactly when the glitch occurred.
I have tidied a few things up & it seems to work correctly now- I should try to make it fail again to close the problem - time permitting, further updates may follow.
Regards
Andy
Have you tried copying everything and pasting it into a new worksheet, and then tried to save that?
AndyWesterman12-AmethystAuthorAnswer
Thanks Richard,
This helped.
Regards
Andy
