JeffH1
Prime 3.0 Started Printing Blank Pages
My installation of Mathcad Prime 3.0 on Windows 7 just started printing blank pages whenever I try to print a document.  I printed several documents just a month or so ago with no problem.  It doesn't matter what printer I use or if I print to PDF; I get the same result.  I'm wondering if there was some update to Windows 7 that clobbered Prime's ability to print.  Mathcad 15.0 M045 is printing just fine.  I even re-installed Prime 3.0 and it didn't fix the problem.  Any thoughts would be appreciated.  Thanks!
JeffH1
JeffH1Answer
PTC support has confirmed that they can reproduce the problem by installing KB3136000.
Can you post the offending document? Then we can also try, and see if it's the document that's the problem.
I'm actually having the exact same issue. The problem arose unexpectedly about two days ago. I tried reinstalling printer drivers and also printing to a separate printer to no avail. In addition, I tried printing to a PDF but this also resulted in a blank file.
What Windows OS are you using?
Windows 7 Enterprise Service Pack 1.
do you use Mathcad Prime 3.0 with commercial license -OR- do you use Mathcad Prime 3.0 Express ?
MH
I don't know about the OP but I'm using Mathcad Prime 3.1 with an academic site/volume license.
In this case you can submit a support request here:
PTC Academic Program | Academic Technical Support | PTC
Academic Case Logger
Jeff,
Any update on this? Just wondering if you happened to have resolved the problem.
JeffH1
JeffH116-PearlAuthor
Still no luck.  Tried printing today.
To address some of the items above:
1. Vlad - Windows 7 Enterprise SP1
2. Martin - Mathcad Prime 3.0 (Commercial license - not that that should matter)
3. Richard Jackson - Document doesn't matter.  If I open a clean sheet and just put some random text on it, it prints as a blank page.
4. We have patches from Microsoft installed weekly.  It's entirely possible that one of these broke it, but I can't go back.
Dave, misery loves company, but not in this case, I think.
I've put in a trouble ticket with PTC,   I'll keep y'all posted.
