Prime 5 incorrect derivative
If it isn't obvious from my subject, I'm using Prime 5.  I've run into a few issues where a partial derivative will incorrectly evaluate both symbolically and numerically as 0.  I've attached two files, both are pretty stripped down just to illustrate what I'm seeing.
The first, derivative_error.mcdx, illustrates the issue with a fairly simple example. You can see that the derivatives with respect to the first two variables are correct but the last three evaluate to 0.
In the second file, derivative_error2.mcdx, all I did was rename essentially everything and the issue magically disappeared.  This has been my only method around this issue to-date.  Move a piece of my work to a different file, play with variable names, eventually things start working.  I've never been able to fix the issue in my original file though.
I've searched this forum quite a bit and haven't seen a similar issue.  I'm either doing something really stupid or getting really unlucky.
Thoughts?
Jon
LucMeekesAnswer
23-Emerald V
This item has passed before (you're not the first to be fooled by the autolabelling feature of Prime). But finding stuff on this forum is difficult, yes.
Anyway, here's the advice:
Check your labels.
In the first file, Rc as parameter of the function A() is labelled 'variable' while the Rc next to d (in the derivation 'operator') is an 'automatic' (marked as '-'). Change that to 'variable' and it should work.
You can find about labels in the 'Math' ribbon.
Same goes for Rd.
The story for Rf is different. Since Rf is not a parameter to the function A(), the partial derivative to it is necessarily 0.
LucMeekes23-Emerald VAnswer
23-Emerald V
Check your labels.
Same goes for Rd.
23-Emerald V
You can change the appearance associated with the different labels. Note that a 'unit' shows as blue, bold and italic (whereas according to international standards it should be in upright font). If you change the appearance of 'automatic' to be drastically different from 'variable' you will immediatley see if two items with the same (spelled) name are different.
I've stated it before, and repeat it here: Prime's autolabelling feature is sometimes a blessing (when detecting units), sometimes a PITA (in cases such as above).
Ugh, thanks Luc.  That did the trick. I didn't even think to check the labels.  I've been burned by those before in converting files from Mathcad 15 to Prime.
The Rf thing was sloppy typing on my part.  It was supposed to be Re.
Thanks again,
Jon
