Prime 6 API for Export/Conversion of Sheets
I can confirm the new SaveAs API function in Prime 6 works well. You can automate and save any existing file to a PDF. What wasn't mentioned is you can also use the function to save as a RTF file format. This can be opened directly in to Word as well. The quality of document in PDF and RTF is exactly the same as the Mathcad document. Very impressive.
