Prime 8: Cant use API with Excel
I was doing some calculations using Prime 7 and Excel through macros. Basically, the program passes some values from Excel to Mathcad to calculate and the results are printed back to Excel. It worked fine.
I recently formatted my laptop and installed Prime 8. I am waiting for the license so, in the meantime, I am using the 30-days trial with full functionality.
I tried to use the same Prime-Excel program but it shows the following error when I run the macro: "User-defined type not defined". I have the Ptc.MathcadPrime.Automation.tlb file to VBA, as shown in the attached image.
Is there something I am missing? Maybe this functionality is restricted to users with license?
Thanks!
Hi everyone,
The problem has been solved. The code I had used the previous Mathcad 15 API commands. It worked fine before because I had Mathcad 15 and Prime 7 installed. So, after I formatted my laptop and installed Prime 8, I got the error.
I deleted:
Dim MC As Mathcad.Application
Dim WK As Mathcad.Worksheets
Dim WS As Mathcad.Worksheet
and left:
Dim MC As Ptc_MathcadPrime_Automation.Application
Dim WS As Ptc_MathcadPrime_Automation.Worksheet
Dim WStest As Ptc_MathcadPrime_Automation.Worksheet
and my script works fine now.
Thanks!
Thanks! Unfortunately, that solution doesnt seem to help with my problem.
My issue is that VBA doesnt recognise the user-defined "Mathcad.application" type, which is part of Mathcad API.
Thanks!
I think the best way how to get the  answer is send your question to PTC Support. Please open Case on PTC Support web page.
Thanks! I will wait for the license, see if the problem persist, and then submit my issue.
But, if anyone had the same issue, please let me know!
DM_1012731612-AmethystAuthorAnswer
Hi everyone,
I deleted:
and left:
Thanks!
