Prime 9, AXIOMsys.exe error
When using symbolic evaluation in Prime 9, from time to time one of two different errors pop up sporadically.
Either a window indicating that AXIOMsys.exe isn't working anymore, or a window indicating that "bad_module_info" is not working anymore.
Nonetheless symbolic evaluations in Prime still work OK, its just annoying and irritating to have to click away those windows from time to time.
Often the same error also pops up immediately after closing Prime.
I am aware that its not a Prime error but stems from Windows - nonetheless is only occurs when using Prime 9.
Anybody has experienced something similar or has an idea what the cause may be?
Found a mention about "AXIOMsys" here ("has a problem with equation system solutions"): https://github.com/daly/axiom/blob/master/book/2005-06.txt
Axiom - "The Scientific Computation System" (Axiom is a free, open source computer algebra system ) : http://axiom.axiom-developer.org/axiom-website/download.html
Werner_E25-Diamond IAuthor
Obviously its just me 😞
So I am closing this thread.
JeffH1
Well, it's not just you.  It is happening to me and maybe others at site as well.  Curiously, there's nothing in the PTC Knowledge Base on this either.  It doesn't hurt anything and only shows up when I close Prime 9.  I simply tell the pop-up to close the program and move on.
Yes. it looks like functionality is not affected. But its sure irritating and as I also experience it while working in Prime and not only after closing Prime, its annoying, too.
And yes, its curious that the knowledge base doesn't show an entry. Actually you are the first one I hear from who experienced that nuisance as well - thanks for letting me know.
