Prime Express Fails to Install
Hello all,
I'm having issues installing Mathcad Prime 4.0 Express on a computer here. Whenever attempted, it returns with this error:
Could not access network location [MSIINSTALLPATH].
Unsuccessful
PTC Mathcad 15 M045 or later is required to convert older
Mathcad documents to PTC Mathcad Prime 4.0.
To enable conversion functionality, you can download and install
PTC Mathcad 15 M045 or later by visiting
 <http://www.ptc.com/engineering-math-software/mathcad/free-trial|http://www.ptc.com/engineering-math-software/mathcad/free-trial>
Whenever you try installing Mathcad Prime 4 Express, it shows up on the screen that the program will try to update from Mathcad 15 M010 despite it not being installed before.
VladimirNAnswer
Is it possible for you to write files in the temporary directory?
I have the same problem...
Do you install the program in the default path?
DrakeD1-VisitorAuthor
Yes, but there's nothing in that folder except for the Diagnostic Tools and some sort of Prime Express config file. Maybe it does have something to do to it, here is the contents:
<?xml version="1.0" encoding="utf-8" standalone="no" ?><EXTERNAL_INSTALLER>
 <PRODUCT appshipcode="M010" datecode="2017110" family="PTC Mathcad" name="PTC Mathcad Prime" parent="msihybrid" shipcode="M020" tag="mathcad.xml" version="4.0">
 <PROPERTIES>
 <PROPERTY name="installdir">[PROGRAMFILES]/PTC</PROPERTY>
 <PROPERTY name="cachedir">[APPLICATIONDATA]/PTC Download/[MEDIAID]</PROPERTY>
 <PROPERTY name="ARPURLUpdateInfo">https://www.ptc.com/cgi/cs/apps/SftUpd/SftUpdProd.pl</PROPERTY>
 <PROPERTY name="ARPURLInfoAbout">http://www.ptc.com/product/mathcad</PROPERTY>
 <PROPERTY name="[INSTALLBASE]">C:\Program Files\PTC</PROPERTY>
 <PROPERTY name="[LP]">[INSTALLBASE]/Mathcad Prime 4.0</PROPERTY>
 <PROPERTY name="[OpenWith]">Open With PTC Mathcad Prime 4.0</PROPERTY>
 <PROPERTY name="[ICON]">[LP]/install/nt/prime.ico</PROPERTY>
 <PROPERTY name="msi.dll.version">3.0</PROPERTY>
 <PROPERTY name="NoUninstallEntry"/>
 <PROPERTY name="NoPTCInstallRecord"/>
 <PROPERTY name="NoLPInstaller"/>
 <PROPERTY name="NoRegistryActions"/>
 <PROPERTY name="NoServices"/>
 <PROPERTY name="NoScripts"/>
 <PROPERTY name="NoShortcuts"/>
 <PROPERTY name="NoLPXmlLog"/>
 <PROPERTY name="LateLPXmlLog"/>
 <PROPERTY name="NoCreateLP"/>
 <PROPERTY install="Y" name="InstallMe"/>
 <PROPERTY name="CustomActions">true</PROPERTY>
 <PROPERTY msgid="145031360" name="NewerMSIAlreadyInstalled">pimPrimeNewerMSIInstalledError</PROPERTY>
 <PROPERTY msgid="145031361" name="SameVersionMSIAlreadyInstalled">pimPrimeAlreadyMSIInstalledError</PROPERTY>
 <PROPERTY msgid="145031452" name="SameVersionMSIMathcadMessage">pimPrimeSameVersionMSIMathcad</PROPERTY>
 <PROPERTY name="NoPostCopyMSI"/>
 <PROPERTY name="MATHCAD15_UPGRADECODE">{9848B3F8-BB46-4678-A786-DB06BB6C637E}</PROPERTY>
	 <PROPERTY name="ToolTip">Document your design intent, calculate complex geometries or validate existing model parameters with this FREE download of PTC Mathcad Express.
NOTE: PTC Mathcad is officially supported on Microsoft 7, 8.1 and 10 OS platforms using the Microsoft .NET 4.6.2 framework.</PROPERTY>
 <PROPERTY name="[PROGRAMFILES]">C:\Program Files</PROPERTY>
 <PROPERTY name="[PROGRAMFILESx86]">C:\Program Files (x86)</PROPERTY>
 <PROPERTY name="[APPLICATIONDATA]">C:\Users\cnainstall\AppData\Roaming</PROPERTY>
 <PROPERTY name="[APPLICATIONDATA_ALLUSERS]">C:\ProgramData</PROPERTY>
 <PROPERTY name="[DOCUMENTS_ALLUSERS]">C:\Users\Public\Documents</PROPERTY>
 <PROPERTY name="[DOCUMENTS_USER]">C:\Users\cnainstall\Documents</PROPERTY>
 <PROPERTY name="[PIM_LOG_ENV]">C:\Users\Public\Documents</PROPERTY>
 <PROPERTY name="[VERSION]">4.0</PROPERTY>
 <PROPERTY name="[SHIPCODE]">M020</PROPERTY>
 <PROPERTY name="[MEDIAID]">MED-60893-CD-240_M010</PROPERTY><PROPERTY name="localhost.msi.version">5.0</PROPERTY><PROPERTY name="UI_started">Y</PROPERTY><PROPERTY name="status_message">Pending</PROPERTY><PROPERTY name="msiexec_errorlog_read">Y</PROPERTY><PROPERTY name="msiexec_return">1618</PROPERTY></PROPERTIES>
 <PREREQUISITE required="Y">dotnet4.xml</PREREQUISITE>
 <DISTRIBUTION from="https://esd.ptc.com/files/PIM/MED-60893-CD-240_M010/">
 <LANGUAGES>
 <LANGUAGE install="Y" installed="N" locale="en_US" name="usascii" required="Y">English</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="fr_FR" name="french">French</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="de_DE" name="german">German</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="it_IT" name="italian">Italian</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="es_ES" name="spanish">Spanish</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="ja_JP" name="japanese">Japanese</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="ko_KR" name="korean">Korean</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="zh_CN" name="chinese_cn">Chinese simplified</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="zh_TW" name="chinese_tw">Chinese traditional</LANGUAGE>
 <LANGUAGE install="N" installed="N" locale="ru_RU" name="russian">Russian</LANGUAGE>
 </LANGUAGES>
 <PLATFORMS onlyone="Y">
 <PLATFORM install="N" installed="N" name="i486_nt">Windows 32 bit</PLATFORM>
 <PLATFORM install="Y" installed="N" name="x86e_win64">Windows 64 bit</PLATFORM>
 </PLATFORMS>
 <PACKAGES>
 <PACKAGE hidden="N" install="Y" label="PTC Mathcad Prime 4.0" name="prime_base" parent="" required="Y">
 <MSI_NAME>prime_msi</MSI_NAME>
 <FEATURE>PRIME_HELP</FEATURE>
 </PACKAGE>
 </PACKAGES>
 <MSI PRODUCTCODE="{F7F13E1C-A30A-406D-9890-FBD24D507867}" UPGRADECODE="{4C14DAE9-CB4C-4FBF-B892-FBCC8B3709C5}" allow_mvsxs="Y" dlsize="251416576" format="silent" from="ptcsh0/PrimeWixInstaller_32bit.msi?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_e2a5adf21ef2284af9ad71255b2801b3" id="ptcsh0/PrimeWixInstaller_32bit.msi" ignoreforupdate="Y" install="N" installed="N" name="prime_msi" orig_value="ptcsh0/PrimeWixInstaller_32bit.msi" pf32="Y" platform="i486_nt" size="550704128" version="4.0.1">
 <INSTALL>msiexec.exe /qb /norestart /I "[MSI]" INSTALLDIR="[LP]" </INSTALL>
 <UNINSTALL>msiexec.exe /x "[PRODUCTCODE]"</UNINSTALL>
 <PROPERTY_LIST>INSTALLDIR="[LP]"</PROPERTY_LIST>
		 <EXTERNAL_MEDIA dlsize="9193" orig_value="contact.vcf">ptcsh0/contact.vcf?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_257a9c4a39dbefa1957974c4e364b3d2</EXTERNAL_MEDIA>
 <MSIFEATURE size="371888">Help</MSIFEATURE>
 <MSIFEATURE size="377400">Engine</MSIFEATURE>
 <MSIFEATURE size="326306">Application</MSIFEATURE>
<!-- Comments run from the character string "less than, exclamation point, dash dash" until "dash, dash, greater than" -->
<!-- uncommented MSIPROPERTY items will be added into the command line install command when run. -->
<!-- Example for silent install with server based install
 <MSIARGUMENT>LICENSEPATHFORM="ServerAndPort" LICENSEPATH="7788@localhost"</MSIARGUMENT>
<!-- Example for silent install with locked license file
 <MSIARGUMENT>LICENSEPATHFORM="FilePath" LICENSEPATH="c:\temp\ptc licensing\license.dat"</MSIARGUMENT>
<!-- Example for silent install with triad license sources
 <MSIARGUMENT>LICENSEPATHFORM="SourceList" LICENSEPATH="7788@localhost;7788@host2;7788@host3"</MSIARGUMENT>
 </MSI>
 <MSI PRODUCTCODE="{F7F13E1C-A30A-406D-9890-FBD24D507867}" UPGRADECODE="{4C14DAE9-CB4C-4FBF-B892-FBCC8B3709C5}" allow_mvsxs="Y" dlsize="294551552" format="silent" from="ptcsh0/PrimeWixInstaller_64bit.msi?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_60e938f440bd051b18b1a58ce606a1bb" id="ptcsh0/PrimeWixInstaller_64bit.msi" ignoreforupdate="Y" install="Y" installed="N" name="prime_msi" orig_value="ptcsh0/PrimeWixInstaller_64bit.msi" platform="x86e_win64" size="660559872" version="4.0.1">
 <INSTALL>msiexec.exe /qb /norestart /I "[MSI]" INSTALLDIR="[LP]"</INSTALL>
 <MSIFEATURE size="574570">Engine</MSIFEATURE>
 <MSIFEATURE size="343698">Application</MSIFEATURE>
<!-- Comments run from the character string "less than, exclamation point, dash, dash" until "dash, dash, greater than" -->
 </MSI>
 <CDSECTION dlsize="47090299" install="N" language="german" name="PRIME_HELP" orig_value="ptc0.cab" size="54616567">ptcsh0/ptc0.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_a20fce2ed412ae2615ab5f7033ac9b88</CDSECTION>
 <CDSECTION dlsize="47027507" install="N" language="spanish" name="PRIME_HELP" orig_value="ptc1.cab" size="54554865">ptcsh0/ptc1.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_e2e16a8c3ac91ff82cab5bd013b490fe</CDSECTION>
 <CDSECTION dlsize="47051817" install="N" language="french" name="PRIME_HELP" orig_value="ptc2.cab" size="54579714">ptcsh0/ptc2.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_2a8f45403bd7045c97e05b11b481a237</CDSECTION>
 <CDSECTION dlsize="47016843" install="N" language="italian" name="PRIME_HELP" orig_value="ptc3.cab" size="54538270">ptcsh0/ptc3.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_a183d3ebf02b37c80764fcd5e9c8823b</CDSECTION>
 <CDSECTION dlsize="47549599" install="N" language="japanese" name="PRIME_HELP" orig_value="ptc4.cab" size="55068106">ptcsh0/ptc4.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_0820cc0ab632c3024b17c4a810cec78f</CDSECTION>
 <CDSECTION dlsize="47275841" install="N" language="korean" name="PRIME_HELP" orig_value="ptc5.cab" size="54794773">ptcsh0/ptc5.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_4026b9b8bd97e230abac41d5378c6a27</CDSECTION>
 <CDSECTION dlsize="47391777" install="N" language="russian" name="PRIME_HELP" orig_value="ptc6.cab" size="54941277">ptcsh0/ptc6.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_bac140aeba788c9f56aa3653254eefd2</CDSECTION>
 <CDSECTION dlsize="47210922" install="N" language="chinese_cn" name="PRIME_HELP" orig_value="ptc7.cab" size="54859470">ptcsh0/ptc7.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_0a7c5b0745bdb479a1d04529519f2021</CDSECTION>
 <CDSECTION dlsize="47298736" install="N" language="chinese_tw" name="PRIME_HELP" orig_value="ptc8.cab" size="54934742">ptcsh0/ptc8.cab?dlm=no&amp;wcn=null&amp;cn=null&amp;uname=universalmathcadprimetrialuser@nowhere.com&amp;uid=null&amp;__gda__=1516038288_817d5afa4ce96d0e642f4b60844cbb31</CDSECTION>
 </DISTRIBUTION>
 <QUALITY_AGENT enable="Y" keyname="QualityAgentOptIn" required="Y"/>
 <SHORTCUT allusers="Y" id="prime_shortcut" showenvironment="N">
<!-- These are actually handled in the MSI -->
 <NAME>Mathcad Prime 4.0</NAME>
 <PROGRAMSMENU create="Y">PTC Creo</PROGRAMSMENU>
 <DESKTOP create="Y"/>
 </SHORTCUT>
 <CUSTOM_ACTION dest="[SOURCE]" dll="" name="Prime" when="PreInstall"/>
 <CUSTOM_ACTION dll="" name="PrimeConfigure" when="PreMSIConfigure"/>
 <CUSTOM_ACTION dest="[LP]/help/project/WEB-INF/config.dmpcf" dll="" name="RefreshHelpXML" template="[LP]/help/project/WEB-INF/config.dmpcf.backup" when="PostCopy"/>
 <CUSTOM_ACTION dest="[LP]/misc/contact.vcf" dll="" file="[SOURCE]/contact.vcf" name="CopyFileToDest" when="PostCopy"/>
 </PRODUCT>
</EXTERNAL_INSTALLER>
VladimirN24-Ruby IVAnswer
