Print Preview Crashes
I have been running MathCad 14 with Windows 10. Print Preview was working but now when I try to use Print Preview it crashes and MathCad shuts down. I tried repairing the installation but this did not fix the problem. Any suggestions?
23-Emerald V
This at least looks similar to an old problem. see here: https://community.ptc.com/t5/PTC-Mathcad/Print-problems/m-p/201375#89792.
Apparently it should be fixed with release M020 of Mathcad 14, per http://support.ptc.com/appserver/cs/view/spr.jsp?n=1425078.
You should be able to download M020 via: Mathcad Downloads.
Thanks. I remember now this problem from when I originally got Mcad 14. I recently had to re-install it on a new computer because my old one died and I completely forgot about the updated release.
I downloaded M020 and installed it. Although I get the message that it is installed, now I cannot access the help files. When I try to do so, I get the message:
The path to your resource center C:\contents.hbk is incorrect. Run the installation of the resource center and Help to correct the problem.
How do I do this?
-MFra-
Hallo JR,
Mathcad 14 works fine with Windows XP (even with SP3). I have doubts that it can work just as well with Windows 10.
However, try disabling the automatic calculation, in this case the preview should work.
Bye
FM
I have had some trouble installing and with installing the updata (M020) but once installed it seems to be working with Windows 10.
