Printing, list-combo box
when i print a sheet that has list combo boxes, some times the items in the box show up when i print the sheet, and some times they dont as shown in the attached sheet. How can i make it to always show the items in the list combo box when i print the sheet? Thanks!
I have just printed it to pdf and it worked ok.
Have you tried printing to pdf?
Could you provide the worksheet.
SFares14-AlexandriteAuthor
Hello Mike,
when i try to print it again it does show up. I am not sure why the inconsistency in printing. Thanks!
This has come up before, and it has to do with your printer drivers. The solution is to print to a pdf, and then if you want a hard copy print that. The same problem occurs with some pdf printers too, so you have to use one that works. I use CutePDF, which is free.
Thank you Mike and Richard. I will try your suggestion.
