problem defining a function that has variables with units of measure
I tried to define the function so that all the units of measure would cancel out and one would produce a dimensionless mass fraction but MathCAD thinks I am doing it incorrectly.
Please explain what I am doing wrong or provide a workaround.
Thanks!
23-Emerald I
Yours looks like it should work.  But you can try this:
°C is actually a function that converts your input to a temperature.  Mathcad has to treat °F and °C differently than the other temperature units because they are not zero-based (not sure this is the right terminology).
Because °C is a function and not a unit, you cannot just divide by °C.  You need a function that gives you the inverse temperature.  You can write your own function like this:
Or you can see another option here: https://community.ptc.com/t5/PTC-Mathcad-Questions/Inverse-Temperature-Units-in-Prime/m-p/347471#M135794
Here are the two options implemented to your function:
(Mathcad 3.1 attached)
-MFra-
My answer is very similar to that of FK:
Give it a try and evaluate (60 °C) /( 1 °C) - you won't get 60!
MFG has explained why.
-MFra-
Was gibt's, Schläfer?
