Problem installing Mathcad Prime 4
Hello PTC Community,
I just removed Mathcad Prime 3.1 to install the 4. version.
But in during the installation process, the installation fails at just 1%.
What is the reason for this?
23-Emerald V
August 28, 2017
If you provide more information about the installation failure, someone might be able to give a clue.
(How did it fail, was there any message, etc...)
Also, for further info, look here: https://community.ptc.com/t5/PTC-Mathcad-Questions/Mathcad-Prime-4-0-installation-problems/m-p/129532
You did NOT need to de-install Prime 3.1 before installing Prime 4. All versions of Prime can co-exist, installed and usable, on the same windows machine.
e.g. I have the express versions of both Prime 3.1 and 4 installed and running on the machine that I'm currently using.
Try to contact with PTC tech support by using "Mathcad Support Center": http://support.ptc.com/support/mathcad_supportCenterOpt.htm
