Problem when calculating with units
Hello!
I'm a new mathcad-user, and I have some problems with calculation of the displacement of a hydraulic motor.
PTC Mathcad obviously calculates differenz results, when using units and no units ! ????
calculation without units:
q = ( (590,72 * 2 * PI) / 380 * 10^5 * 0,9 ) * 10^6
q = 108.526
calculation with units:
q = ( (590,72N*m * 2 * PI) / 380 * 10^5Pa * 90% ) * 10^6
q = 102.82cm^3
Please help me!
Many thanks in advance!
BR
Paul
23-Emerald I
Mathcad understands units, and will convert to adjust. I think you converted an old equation that had a unit conversion facor in it.
See attached.
That's certainly not what I see:
This is why it's best to post a worksheet with your question. Without a worksheet it's not possible to say why you are getting the result you see.
23-Emerald I
Take the million (unit conversion factor) out of the equation with units, viola!
That's not going to yield an answer of 102.82cm^3
pbreuer1-VisitorAuthor
Hello Fred!
Hello Richard!
Many many thanks for your prompt and good support.
After checking my worksheet again some hours later I found the mistake.
I defined some variables, two of them had nearly the same name and in my calculation I used the false one!
Sorry for contacting with my greenhorn mistake!
BR
Paul
