Werner_EAnswer
Here is an approach using "minerr"
Sure you can find a fit using a solve block with minerr and ever so often this has some advantages over using the built in "genfit" function.
But I doubt that the approach as posted by you ever worked in older Mathcad versions. We had to see the pdf to judge though.
Here is an approach using "genfit":
Werner_E25-Diamond IAnswer
Please find in the attachment another approximating model for your data.
FDS13-AquamarineAuthor
Werner and Vladimir, thank you for your help. Fitting data to a standard in ELISA testing can be quite challenging so I appreciated all input.
