problem with my units
  • March 25, 2011
  • 20 replies
  • 12631 views
Dear all,
I have problems with different things on my Mathcad15.
1. when i create equations based on defined variables, the units are not as expected when i enter the unit i want to be as my result unit.
2. when i go to help search, the menu is disabled and only numbers appear insted. but when i press the numbers i get a message that i could have problem with active ontroll function.
3. how can i get the my result from an equation as unitless? the variables are defined with units above
i really need help with this as i have to submitt my course work very soon.
regards
Alan Mardan
Best answer by ValeryOchkov
I would like to show you that you change the value of the variable m and later use mot meter (m) but you user variable m that is mot yet meter.
Attach please the file!
Hi Valery, thanks for the respond
I have highlighted some of the equations and explained what unit i want the results to have. the two main problems are:
1. I can not get a unitless result using my defined variabes which have units
2. some of my equations give me units in kg per something, but all my units are based on either kN/m, kN, m, mm and kNm (For civil engineering)
sorry if my calcs are messy but tried to highlight some of the problems in yellow
looking to hearing from you
Alan
Do not change values of variables m, N etc. They are units - meter, newton etc
See my red operators in the attached file!
This promlem is solved in Mathcad Prime!
Given your point 2. I would suggest that you have an installation problem.
If you open the tutoriuals at one of the units examples, does it give the same problem. Use the address toolbar in the resource centre window to find its true location, and then open directly in the main mathcad to avoid differences between the resource centre execution and user sheet execution.
Good luck.
Philip
Hi philips,
I had a virus on my computer and started to remove things from internet explorer as the virus stopped my antivirus from workin. So i removed things from explorer and i think some thing wrong went in between there.
regards
Alan
Alan,
Go to add/remove programs and repair Mathcad. That should help if you accidentally uninstalled something.
Mona
I'm also having a problem with units.I am solving two equations with two unknowns symbolically. The results come out looking like this:
-(15 digit number) x lb x -(15 digit number) x ft^2 + (15 digit number) x in^2
ft^2
If I then copy that complicated expression and type '=' after it mathcad does the reduction and puts out the correct answer, in pounds, to four significant figures like I have directed. But why doesn't mathcad reduce all those ft and in and come out with the correct answer directly?
The symbol Math of Mathcad does not Know what it is units - 100 cm=1m 1000 gm=1kg etc.
Send your sheet and we will try to help you.
I think I now understand.But in case you can show me a better way to solve simultaneous equations I have attached my entire worksheet. I have had the same thing happen on page 2 twice, and page 3 once. In the "(15 digit number)" in my original post the "15" was only approximate.
