Problem with ODEsolve
Hello everyone!
I have a question, how can I solve a system of equation, which is consists of three equation (two of them are Differential and other one is not) using ODEsolve or there is some other way?
So I had a system of two differential equation and everything worked just fine, but then I need to add one more equation and this equation is not differential. So I don't know are the ODESOLVE able to solve this kind of systems or not. It keeps telling me, that I have too few initial conditions. File 9 is a file where only 2 equation are solved.
Thanks for your help
-MFra-
Hi Vladimir Novikov,
first of all you should do the following changes:
.) The whole sheet is unitlesse - otherwise I guess we would experience severe problems with odesolve in Mathcad 15 (thats better in Prime). So Vladimir decided to write the supposed units next to the values in a textbox or separate math region for documentation and reference purpose only. This has no effext on the calculations.
I guess Valery would define every unit as being :=1 and then attached them in the unit field.
.) the equations with the "j" also are for refernce purpose only and have no effect on the calculations.
At the moment I haven't digged far enough in the calculations to be able to provide a solution but I guess the problem is, as Vladimir already guessed, that one of the equations is not an ODE.
-MFra-
I would say that not all the units are written in text boxes, on the contrary, many are written as if they were variables. The first (° C) for sure.
Attach is an absolutely unsatisfactory solution by turning phik into a function in an extra solve block.
I had to limit tau1 because of a strange error if its too large and the phi solve block takes quite long to calculate for higher values of tau.
Maybe its a tolerance problem because of too hight or too low values - when I set TOL to a lower value liek 10^-9 the odesolveblock fails for lower values of tau1, too.
Hope somebody has a better idea to tackle with that system.
vnovikov1-VisitorAuthor
Thanks for help, but I need something little bit different. The main idea is to get a function of phik(tau) from the third equation to insert it in two previous equations. So I will get function of temperature and radius related to changing relative humidity (phik).
Yes, if my solution would work OK, which it obviously doesn't, you could, after solving for TK and RT, define phi_k(tau):=phik(TK(tau),RT(tau)) and you have the demanded for function. A bit inefficient, as the every call to this function phi_k would call the odesolveblock twice.
Here is what I get with tau1=250 AND TOL=CTOL=10^-3.
Setting CTOL to 10^-4 or lower and/or TOL to 10^-6 or lower makes the block fail (lower values for tau1 work OK). This may indicate a convergence problem. Cause could be values near the limits (too large or to low) or a problem with the equations used.
There seems to be an abrupt jump right at the beginning.
Not sure if thats what you expect. If not, you may wish to check your equations.
For whatever it may be worth I attach the sheet with the settings for CTOL and TOL which work for me and added phi_k at the end.
