problem with root function
- April 14, 2011
- 2 replies
- 2717 views
in the attached MC12 file I'd like to find the root of a function for several values of one of the variables and tried to use the root function. The algorithm does not converge for certain value of the variable x, although the Find function is able to find the root for each x-value. Is there a way to make the root function to work or is there another way to do this?
Gigi
