Problem with symbolic simplification
I'm frustrated   trying to simplify   results from   symbolic   engine (new or legacy). i have tried multiple symbolic   options.
For some reason, if I go in and   manually do an   equate, stuff sort of works?
Prime 6 file.
LucMeekesAnswer
23-Emerald V
Are all your t's of the same label?
23-Emerald V
It's a known fact that the output of the  symbolic processor is hard  to control.
In your case maybe the keyword  'collect, exp' helps.
Thanks for lookig, Luc -- but your suggestion does not work.
Since you're running   Mathcad 11, can the Maple  engine   do a better job?
23-Emerald V
Don't have it at hand.
Try 'assume,t>0'
