Problem with units
I'm having the following issue with the units in mathcad15:
L:=20.76m
Then when I go to repeat L later in my sheet it comes out as L=0.
Anyone got any ideas how I can solve this issue? I'm having the same problem even when I change L to Beam for example.
Mike
On page 7 of 9 you have defined m as zero.
Try not to use varibles names which are units. Just call it m1 or something similiar.
Mike
No, have a look below. Can you post the worksheet?
Mike
MikeCivil1-VisitorAuthor
Mike,
I've added the sheet, the problem is on page 10 and highlighted in red.
Cheers,
Mike
Mike
