program in function definition corrupts vector?
"This value must be a scalar"
Why does the standard lognormal (Pr_lnorm) work
but when I introduce a program into the function definition (Pr_tlnorm), I get the above error?
JKTAnswer
... or
if you expect only vectors are arrays as input for id..
If you want to call a function which, like yours, expects a scalar argument "id" using a vector instead and expect this vector to be fed element by element as argument of the function and the various results to be collected in a result vector, you have to use vectorization!
JKT13-AquamarineAnswer
... or
Thanks @Werner_E and @JKT
I'm not familiar enough with Mathcad (or perhaps maths) to be sure what the difference is between the two solutions, but the latter solution by @JKT does appear to offer the benefit of baking in the vectorization at the function definition stage.
