program to compare 2 matrices
- 7 replies
- 5387 views
- Translate All
I need to write a program to compare two matrices and eliminate non-identical rows. For example, please see attachment. In this case Matrix B can only contain numbers found in Matrix A. I need to compare each value of A with B and output values of B that matches with A (in the same order). Problem is some of the numbers in A do not appear in B and therefore, I am not able to use the match function. I would greatly appreciate any help.
Thanks.
