Program Trouble.mcd
  • December 2, 2011
  • 4 replies
  • 1876 views
This is MathCAD V2001i document wherein I show my initial
problem and two solutions that became apparent from the help
provided by the PTC Community. The solution provided by Fred
K. was closest to what I ended up using and was the simplest
for my one-dimension, stacked matrix. Paul
Paul,
Does really require a new document creating? You could have posted this within your thread.
Mike
pdorvel1-VisitorAuthor
Thanks for the tip. Will do. Paul
Use the option "Use advanced editor" to attach to the message your file.
I kind of like the document post.
The worksheet goes through a "cleansing" process within the discussion thread. And then the worksheet is remade into a document, all polished and shiny.
Then members can rate and comment on the document indicating how useful and elegent the solution is.
