Programming a Z-score Table
Hi, I need assistance debugging a program to build  a Z-score table with the intention to reproduce in Mathcad a z-score table very similar to the one that we could create with an excel spreadsheet. This just for fun!
See attached files.
Thank you
juan
Werner_EAnswer
> I used the integral instead of the function pnorm because this is the only way that I can funnel the sum of the vectors X & Y into the limit of integration Z.
I see no problem in using that sum as argument of the pnorm function.
> Your suggestions of modifying T did not work for me
Additionally you have to use Z instead of T in the last line. After all you want a Z-table, not a T-table 😉
Regards
Werner
Why do you post a pdf and not the worksheet itself??
Guess you should use T[r,c as upper limit of your integral in makeTable and not simply T.
Better way is to write T <--  a[r + b[c and then use T as upper limit as you have. No need to create a vector T.
Why do you program the integral yourself? Mathcad provides the "pnorm" function!
jsuarez1-VisitorAuthor
Hi Wegner,
Finally I could upload the Mathcad file now. I tried many times at the time of sending my post without success. Here is the file to be look at.
If you can do it using  both methods is excellent, then I could compare both of them
thank you!
juan
Werner_E25-Diamond IAnswer
Regards
Werner
Please attach your Mathcad worksheet.
I attached in a previous post last night , but it is waiting for the moderator for approval (more than 16 hrs). I resubmit it again.
