Jul 19, 2019 7:34 AM UTC
PTC Mathcad Prime 5.0: Greek symbols in Text Blocks
Hello PTC Community,
While using the new Mathcad Prime, I was unable to insert Greek symbols in text blocks. Is there any way to do that?
Thank you.
Derbigdog
DerbigdogAnswer
Jul 22, 2019 2:37 PM UTC
There are two ways to do this. Pick a font that has Greek letters or embed a math region using Ctrl-m then you can either pick the symbol from the Symbols chart or put in the roman letter equivalent and then use Ctrl-g to convert it into the Greek letter you need.
23-Emerald V
Jul 19, 2019 7:58 AM UTC
Certain characters are available in the standard set. Otherwise use a font with Greek characters...
Jul 19, 2019 11:53 AM UTC
Prime is quite limited compared to real Mathcad.
As a workaround you may insert a math region with the appropriate greek character.
Or you may startup "charmap.exe" and copy and paste the characters you need.
Derbigdog
Derbigdog15-MoonstoneAnswer
