amcgough
May 19, 2026 4:08 PM UTC
PTC Mathcad Prime Worksheets Directory - Algebra & Geometry
Full topic list
Want a Mathcad Prime 30-Day Free Trial? Download your copy today.
All worksheets created in PTC Mathcad Prime 2.0.
Worksheet name Description
Complex Numbers in PTC Mathcad This worksheet using PTC Mathcad shows you how to work with complex numbers when using PTC Mathcad software.
Cubic Spline Interpolation This worksheet helps to differentiate between regression and interpolation. Regression is a mathematical process that attempts to find a best-fit curve through a set of data. Interpolation allows you to estimate values between measured data points.
Eigenvalues and Eigenvectors in PTC Mathcad This worksheet using PTC Mathcad shows you how to use the PTC Mathcad functions "eigenvals" and "eigenvecs" to find the eigenvalues and eigenvectors of a matrix.
Random Triangles in the Unit Square This worksheet using PTC Mathcad supposed that three points are independently and uniformly chose in a unit square to determine a unique triangle.
Seeded Iteration in Mathcad This worksheet using PTC Mathcad shows you how to iterate through a variable based on an initial seed value.
