question
Dear Expert,
Regarding EN_NR1 and NR2 loop statement (left two algorithm), I got a diifferent results from one of Maple software because I guess I might made some fault in the loop but I couldn't find out hence I need your support !!
What I want to make in EN_NR1 and 2 is that
initial value x1,x2,x3,r1,r2,r3  should be updated whenever Xnew evaluate from Jinv with for loop and while loop but It seem it doesn't work... on the right graph from maple software, the black curve doesn't excceed 200 value at y axis but my mathcad say the black curve(EN_NR2) excceed over 1000 value even though the input is same both maple and mathcad.
hence Could you support me? Thanks in advance
P.S. My concern content will be located on last page in attached file
Can you attach Maple worksheet in PDF format?
